Grapple Grapple research and tentative conclusion what may be best for me; what do YOU think?
   / Grapple research and tentative conclusion what may be best for me; what do YOU think? #11
That is from Gator Attachments (formally Markham Welding) How do I know?...because three of the pictures are mine! I sent them to Mellisa years ago.
The one you linked to does not look like any Markham/Gator grapple I've ever seen. It is a used clamshell. Did you mean to link to the other ebay item that RJJR posted? That one does look like a Markham/Gator.
Yes, I linked the wrong one...thanks for catching that:eek:
   / Grapple research and tentative conclusion what may be best for me; what do YOU think? #12
I'd have a problem paying $3500 for a fel grapple. Maybe I'm just a bit tight.:eek: But....you could buy THREE of some other brands at that price...no?
I have a 48" markham/gator and have had some problems with it due to their Deere mounts and have bent the tines a bit.....no biggie on the tines. Still, (with my re-inforced mounts) it gets the job done pretty well.
I do think the lower grapple teeth could be about 1/3 shorter in lenth on this Markham design.....for CUT purposes. This would provide less weight and less leverage on the FEL....as well as more manuverablity and do a better job of "rooting" and grubbing the soil.....but still retain the ability to carry high-volume brushy loads.
I'm ok with what I have.....but an enterprising grapple-builder could slightly modify the markham gator affair to provide a "blend" between the old milonzi grapple and the markham - which would be the best of both worlds for CUT tractor grapples. (IMO) ;):thumbsup:
   / Grapple research and tentative conclusion what may be best for me; what do YOU think? #13
I agree. I like the slightly wider upper jaw on the Markham design and also that the upper jaw overlaps the lower a bit when closed. I also think the curved lower tines on the Millonzi are more useful than the straight bottom tines on the Markham/Gator. Shortening the bottom tines is an interesting idea but it would result in a slight net decrease in volume capacity. Maybe my Millonzi already has shorter lower tines, I've never measured. I presume the Gator fabricators are using CAD based design and some sort of automated steel cutting system so it really shouldn't be that difficult to make these types of modifications.
   / Grapple research and tentative conclusion what may be best for me; what do YOU think? #14
I'm also researching a future grapple purchase, what's everyone's opinions on versetech? I have to agree with with the comments that you shouldn't typically need the ultra heavy duty 3K grapple....
   / Grapple research and tentative conclusion what may be best for me; what do YOU think? #15
I have a Versatech on my 4540 Montana. It was used unmercifully by the PO who used it in a tree removal business after Katrina. Other than the tips of 3-4 tines being bent, it works great. And the way it's made it will hold small items, just not clamped. And his original 2006 invoice says it was $1600.
Not a great pic but you get the idea.
   / Grapple research and tentative conclusion what may be best for me; what do YOU think? #16
I have a Versatech on my 4540 Montana. It was used unmercifully by the PO who used it in a tree removal business after Katrina. Other than the tips of 3-4 tines being bent, it works great. And the way it's made it will hold small items, just not clamped. And his original 2006 invoice says it was $1600. I'll see about adding a pic of it.
Kool....thanks for the QUICK review! :)
Is it a single or double cylinder? 60, 66"??
   / Grapple research and tentative conclusion what may be best for me; what do YOU think? #17
Double cylinder; one on each clamp. I haven't measured but probably a 66" if not bigger.
   / Grapple research and tentative conclusion what may be best for me; what do YOU think? #19
If I bought this thumb grapple for my loader on my NH - TC -29 would I need to add more hydraulics and if so is that a big expense...Thanks
Tractor Grapple for skid steer or frontend loader | eBay
Others can answer that better than I can... but, yes you have to have hydraulics for the clamps but I THINK you can actually slave off of some of the FEL hydraulics. Everythingattachments.com has some videos and I believe there is one on doing that. Go here... How To Video Demos - Implements & Attachments and look for "3rd function hydraulics". I'm blocked here at work so I can't check it but I think that will answer your question.
   / Grapple research and tentative conclusion what may be best for me; what do YOU think? #20
First, that is pretty expensive for a bucket grapple jaw. I think these usually can be had for around $300-400 on ebay.
Second, yes you will need hydraulic ports and controls. The simpliest set up is to use rear remotes. Rear remotes can be installed usually for about $400 for a kit and an afternoon of your labor or a few hours of dealer mechanic rates. If you have rear remotes already then you just need a pair of long 3/8 inch hydraulic lines, a pair of shorter hydraulic lines (from grapple to tractor torque bar) as well as 6 quick connects. That will cost you something around $200 over the internet or maybe $300 from a hydraulic shop.
A more expensive option is to put in a diverter valve ($600-700 kit) or electric over hydraulic kit ($900 or so) plus labor (3hrs) if you don't do it yourself.
I used rear remotes on my first tractor and a diverter valve on the second. Both work just fine. The electric over hydraulic is pricey but very nice. If you don't have rear remotes there is an advantage to getting a set as there are many other uses (topping lift for example) that you can benefit from.
2016 Ford Explorer AWD SUV (A55853)
2016 Ford Explorer...
2004 Fleetwood Wilderness Advantage 365 BSQS 38FT T/A 5th Wheel Travel Trailer (A53424)
2004 Fleetwood...
BUSH HOG 2820 LOT NUMBER 125 (A53084)
BUSH HOG 2820 LOT...
Kuhns AE10 Small Square Bale Accumulator - 10-Bale Efficient Handling System (A55301)
Kuhns AE10 Small...
Willmar 4550 Wrangler Articulating Loader (A55314)
Willmar 4550...
