Utilities to a new pole barn
   / Utilities to a new pole barn #1
kwahl
Western NY
John Deere 4320
Hello All!
I am building a pole barn approximately 200' from my house and want to run the PVC for conduit while I am putting in the pad. I would appreciate your insight on what conduit I should run for Water, Propane, Electric and Telephone. Should I run one 4", multiple 2", not quite sure what can or should go in the same pipe. I am in the northeast so I am going down 4', plan on running flex for the water, clueless as of this point what to use for the propane and electric. Help very much appreciated!
   / Utilities to a new pole barn #2
Your local zoning rules will dictate what you need to run, materials, depth etc...
Here, they have to have the trench open for inspection, so pre-running them is of no value for anything that needs the inspection.
   / Utilities to a new pole barn #3
Around here they specify what has to be separated from what and by how far. For water we mostly use polyethylene, not sure what flex is. Electric here doesn't have to be in conduit, but generally goes in PVC for protection, I used 3" to go about the same distance. Propane can either go in steel pipe, or there's a special plastic pipe made for carrying gases. Phone can't be too close to electric line, you'll get interference. Here they bury the electric about 3', backfill, then throw the phone line in on top so it's only about 6" below the surface. I'd put the phone in PVC if I were doing it.
   / Utilities to a new pole barn #4
Are you wanting to run all 4 utilities from the house 200' away?
That would make me consider a seperate new popane tank at the new bldg.
21/2" should be fine for the elec. but it really depends on amps/conductor size and count that you feed your new sub panel with. If you mean that you just want to "stub out" from under the slab until you get the inspectors out of the picture (good idea) then run a seprate conduit for each use. More details needed.
   / Utilities to a new pole barn #5
Youll have to contact propane company to see what they require for their service. at 200 feet they may require an additional tank, or may let you piggyback off of their existing tank. Here in Idaho they use a poly pipe and run the high pressure to the building. Electrical will have to be in its own conduit or rated burial cable and kept at least 12" from propane, water and phone.
Phone can be direct burial but most put it in conduit to protect the pipes.
Water in its own pipe.
You CANNOT run water,gas,phone and power in one pipe...nope...no way
What we generally do here is dig a 4' deep hole and first run the water. then fill in 12" of clean dirt, then run power and gas, each to one side of the 18" wide trench. Then fill in 12" dirt, then run the phone . fill trench.
Thanks for all the great insight. I will follow-up with the propane company and building dept. in my area.
   / Utilities to a new pole barn #7
The color of the conduit should be considered for what utility will run in it as well.
   / Utilities to a new pole barn #8
Are you running any of this under a driveway or road? There may be additional code for that compared to just running it under sod.
   / Utilities to a new pole barn #9
I sure would hate to chase a water leak in that trench.:eek:
   / Utilities to a new pole barn #10
I just faced similar issue. I run power in separate trench two feet deep.
Then I run water 6ft deep filled the trench to two feet and added propane and two 1 1/2" low pressure (sprinkler) hoses as conduits for Ethernet, phone, intercom and other low voltage stuff. I used a vacuum to thread a rope trough the pipes. I put a piece of Styrofoam on the end of the rope and sucked it trough the pipe.
When running a phone line use CAT5 or CAT6 wire instead of phone wire.
2010 Case 650L Crawler Tractor Dozer (A50322)
2010 Case 650L...
2008 Ford F-250 Pickup Truck (A50323)
2008 Ford F-250...
2021 Ver-Mac PCMS-3812 Solar S/A Towable Trailer Message Board (A49461)
2021 Ver-Mac...
2003 Big Tex 10PI 16ft. T/A Pipe Top Utility Trailer (A49461)
2003 Big Tex 10PI...
2025 REDEDLIFT CPD25-XD4 FORKLIFT (A51222)
2025 REDEDLIFT...
2019 HINO 155 16FT BOX TRUCK (A50505)
2019 HINO 155 16FT...
