Backhoe frame adjustment for wood BH80-X backhoe
   / frame adjustment for wood BH80-X backhoe #1
bironacad
Southern Ontario, Can
New Holland 3045/2010
I finally got around to getting out the backhoe for the first time which required mounting it. The concept is not difficult to attach it but the alignment seems out. If you line up one side of the frame on the hoe to the tractor mounting frame the other side of the hoe frame would be a 1/4 to 1/2 inch out. We finally got it on but it required an interference style fit. Is this normal? has anyone adjusted the hoe mounting frame? and how did you do it. We thought if we just loosened the frames adjustment lugs while it was attached to the tractor it would almost self adjust. Any experience with this?
Thanks
   / frame adjustment for wood BH80-X backhoe #2
Have you sorted this out yet?
What do you mean by "an interference style fit?" Maybe a couple of pictures would help.
I have this hoe on a TC-30. The dealer mounted the frame and made any adjustments, if any.
Getting the tractor frame lined up and square with the brackets on the hoe is important.
   / frame adjustment for wood BH80-X backhoe #3
I have this hoe on a Kubota B3030 and the hoe slides into the sub-frame without much issue. It's tight but the frame and hoe line up. My sub-frame
mounts directly to holes in the axle housing. If yours is similar you may be able
to put some spacers on one side.
You should be able to download the installation manual from the Woods website as that might give you some insight as to what may be wrong.
Vic
Vic
The frame on the hoe was a 1/4" off, you would line it up one way and it would not mesh on the other side. We wrapped a large cargo strap with a winch and pulled in the frame and retighten her up and now she fits fine, took the ten minutes to put it on :)
The frame on the Hoe is adjustable for width, the adjustments we made on the weekend made it a much simpler job to attach. I really like the rear view camera idea that 4shorts mentioned in the best modifications thread that would take at least one in and out of the cab out in out, lol. The frame width can be change up to at least and inch if it is not done right it stands to reason that the attaching will give challenges. I really feel my dealer's service department sort of dropped the ball on the predelivery preparations on the new tractor. Things are getting there though with no complaints for NH and the CVT tractor.:thumbsup:
   / frame adjustment for wood BH80-X backhoe #6
That's great!
If you have a choice, I'd be looking for a different dealer.
2018 PJ TRAILER 32FT GOOSENECK TRAILER (A55745)
2018 PJ TRAILER...
2014 Chevrolet Express 3500 Cargo Van (A55852)
2014 Chevrolet...
CFG Industrail MX15RX (A56469)
CFG Industrail...
ANTHONY CARTS 94LFW-24 OXY/ACCELYNE TANK CART (A57192)
ANTHONY CARTS...
2014 Chevrolet Silverado 1500 (A55973)
2014 Chevrolet...
2011 FORD F350 SERVICE TRUCK (A57192)
2011 FORD F350...
