2008 chevy truck probs
/ 2008 chevy truck probs #1
bigbull338
Elite Member
texas
7040 HDC 1153 fel
this is a post about what all happens when a truck starts crapping out.my brother has a 2008 chevy he uses for a work truck.an a 2009 chevy 4x4 he uses for a back up.well in the last month the 2008 has blown both front hubbs an bearings.plus 1 of the auto doorlocks has burned out because he does alot of stopping an starting.then tues the U-jiont went out on the drive shaft.an the truck has less than 90,000 miles on it.he puts 900mi a week on the truck.he is planning on trading it in 2012 if it lasts that long.
/ 2008 chevy truck probs #2
Sounds like my neighbors 07 and my 05. Glad I went to other brands.
Chris
/ 2008 chevy truck probs #3
Ford people know all about this too. 60,000 miles is about all the wheel bearings are good for, and in the case of Explorers and Expeditions you are changing all 4 at once. Just did this on mine.
see thats the prob he is a die hard chay man no matter what.an im a ford man.when he bought his 2009 i showed him that i could buy a cc 1 ton with auto tranny an big motor for $25,000 pretty much out the door.an he gave $28,000 for a loaded single cab 4x4.
/ 2008 chevy truck probs #5
I have owned about a dozen Ford trucks and SUV's since 1997. Never changed a single bearing. My dad has owned about 6 and same with my BIL and they have never changed any either. Must just be dumb luck.
In reality all the vehicles I have owned, close to 25 from Ford, GM, Dodge, Nissan, Toyota, Honda, ect I have only had to change 2 bearings ever. One in a GM truck, cant remember the miles and a Dodge truck at about 60,000 miles.
Chris
/ 2008 chevy truck probs #6
OK and your point big bull?
This is a 3 - 4 year old truck pushing 100k miles that has been used for work. You don't say what type of work, so I'm assuming a bunch of town driving toting a trailer around hauling weight close to the limits of the truck. U-Joints - $15 - $20 and an hour to put them in. Doesn't sound like to big of deal. A door lock to crap out on something you said that he gets in and out of a bunch doesn't seem that unreasonable either. Granted front hubs could be a bit pricey, but for a truck hauling loads around town doesn't seem that unusual.
If it makes you feel any better, guess how I spent New Year's Eve day? Installing bearings in the front of my Aunt's F150 2wd. 60k miles and the heaviest thing it has ever done is tow a little 5x8 wire mesh trailer. Of course, that is on top of the light switch that has to be turn on/off with pliers because it broke. Can't find one in the junk yard and a new one is expensive. Passenger window won't role down (power), who knows why. Oh, I know why, it is GMs fault the items on the Ford truck broke.
/ 2008 chevy truck probs #7
I agree with you. Its mechanical and things break. If every truck out there of a certain brand had the same problem at X miles then its a major issue. U joints go bad for a bunch of reasons but I would guess its from him not coming to a full stop to switch from forward to reverse. My neighbor has had to put 2 in his 07 Dmax and he does this. Makes me cringe.
Chris
he runs a ruel mail rout 5 days a week with the trucks.thats why he buys 2 new trucks sometimes 6 months a part.so its rough driving day in day out.the point is he over paid for a 1500 4x4.when i could got a farm truck with flat bed for the same price.a new $1500 should be under $20,000.but like everything else they are over priced.
/ 2008 chevy truck probs #9
To address your brother's isses:
- The power door lock feature that lock/unlocks automatically can be turned off. Probably a good idea if he's in an out of the truck so often. I think both the 08 and 09 can be set to olny lock via the button.
- Wheel bearing hub units are finicky. Alignment, road conditions, tire size, aftermarket wheels, road contaminates, and loading all play a big part. Ford, GM and Dodge all have the same problem with these units. And they all fail.
- A U-joint at 90,000 miles is not bad out of a sealed factory joint.
I agree with you on the price. Even "work truck" packages are way to steep.
/ 2008 chevy truck probs #10
90k is not bad at all for a set of front wheel bearings these days. The big three have used a sealed unit bearing for years on the front of their pickups and cars, and these have become a very common wear item. Think how many production steps/workers have been eliminated in building a vehicle using unit bearings vs. old tapered bearings.
I have replaced more unit bearings on more makes of vehicles than I could ever recall.
/ 2008 chevy truck probs #11
I agree with most of the posters here. Almost 100k miles are you are complaining about a few mechanical issues that can happen to ANY vehichle at that many miles.
You think ford, chevy, dodge, etc make their own u-joints and bearings??? Think again. Bearings wear out period. How fast depends on conditions. Dirty, dusty, muddy, wet, etc. Since they are probabally sealed units, there is no way to grease them. A dirty condition can wear out the seals quicker and cause the bearings to fail sooner.
And 90k out of a $20 u-joint isnt bad either.
If he does the repairs himself, the two bearings and 1 u-joint are under $500. I whish every vehichle I owned only had ~$500 worth of repairs needing done ever 90-100k:thumbsup:
/ 2008 chevy truck probs #12
Actually, what all you guys are missing here is his occupation...rural mail carrier. A lot of stop and go, inferior roads, etc.. If that is all he has at 90k, that is pretty good in my book. As far as wear and tear, that 90k on a rural mail route is more like 190k.
that goes to show you how long cars an trucks will last anymore.but hey he does drive on alot of bad roads,but the truck should still last 4yrs.
/ 2008 chevy truck probs #14
And nothing you have said, says it shouldn't. I think everyone here is thinking these are minor repairs and pretty darn good for the abuse - yes abuse, this truck is taking.
/ 2008 chevy truck probs #15
My question would be why is he driving such nice and newer vehichles as a rural mail carrier????????
Most of them around here are driving 10+ year old cars. Relability and mileage are far better. Not to mention that repairs and maintenance are usually cheaper. Like oil changes, tires, etc.
But to each his own. If I was a mail carrier, I certainly would NOT be driving a 2 year old truck. Talk about depreciation:mad: And for the cost of just one of those trucks, he could have 2 or 3 gently used toyotas, hondas, etc.
/ 2008 chevy truck probs #16
I agree with Deerefan..Mail delivery is probably one of the worst things you could do to any vehicle of any type or brand. Pushing 100K with only these problems is a miracle actually.
/ 2008 chevy truck probs #17
Rural mail delivery is SEVERE service. I have a very good friend that does that with a Subaru and probably has more problems than the original poster. Heck I have a Toyota that has given me about this level of problems and I am not a rural mail delivery person. I drive 22 miles in a rural setting one way to work.
/ 2008 chevy truck probs #18
At least blown hubs will still get you home unlike the numerous head gaskets, spark plugs and fuel pumps my personal and colleagues' Ford's have encountered...
Those repairs on that truck are hardly enough to complain about, the transmission should be the biggest problem with all that stop and go. I bet the TC is pretty cooked!
/ 2008 chevy truck probs #19
Good thing he is not driving a Dodge then. They eat trannys like crazy. :thumbsup:
I can play your game all day long.:licking:
Chris
/ 2008 chevy truck probs #20
Chris
Obviously, your "game" is stuck in the early 90's when Dodge's actually had transmission problems. Get with the game DP, Ford's the one with the tranny problem now. :laughing:
