Flashpoint for 75W90 synthetics
   / Flashpoint for 75W90 synthetics #1
3930dave
Super Member
Canada
Ford 3930
How big a deal is Flashpoint for gear oil ?
Application: E350 7.3L 3.55open, will be hauling up to 10K# limit.
I have used Mobil1 75W90 in my rear wheel drive station wagon recently - I have faith it will perform great there.
I was going to p/u more of the Mobil1 for the E350, but I happened to compare specs with Amsoil.
Mobil 1 Synthetic Gear Lubricant LS 75W-90
AMSOIL - Synthetic Gear Lube SAE 80W-90 (AGL)
Flashpoint on the M1 is 150C, Amsoil AGL is 218C. Quite a difference.
Yes, the Amsoil AGL is actually an 80W90 (what Ford specs) but Flashpoint does not appear to be that different in the Amsoil Severe Gear 75W90, so I don't think (?) this Flashpoint difference is driven by the lower viscosity number.
(Funny though, about the Amsoil SG 75W90, it seems to be showing a Minimum of 150C Flashpoint, which would be in-line with the Mobil1. Sigh.... games on datasheets.... ya really gotta read 'em 2,3 times.... at least I do :) ).
As I live in Canada, I want/need the low temperature performance of a synthetic gear lube. Mobil1 might go on sale now and then, but at regular prices, the Amsoil AGL 80W90 and the Mobil1 75W90 retail for about the same $.
What I don't have is a good feel for consumption rates vs. Flashpoint, esp. for gear oil. Comments ?
For my money, I'm leaning towards the Amsoil AGL 80W90, as it's Flashpoint is 68C higher.
Rgds, D.
   / Flashpoint for 75W90 synthetics #2
The flash point is the temperatures at which the oil will auto ignite.
Converting: 1.8 x C + 32 = F
1.8 x 150c + 32 = 302F for mobile one
1.8 x 218c + 32 = 424F for amsoil
If you are running temperatures that high you have other problems.
I would not worry about it.
Thnx Transit...... I'm guessing the main factor in differential gear oil consumption would be seal condition, but I really don't know how big a factor the oil volatility is re. consumption, hence the post here. I do hear your point, re. Operating Temperature.
The only thing I have experience with in this regard is motor oil. Many motors will consume less synthetic than conventional - my guess - this is due to a combination of better sealing properties and Flashpoint of the synthetic.
Partly I'm trying to compensate for my own behaviour..... I will check motor oil levels fairly often, differential levels all too rarely.
Rgds, D.
   / Flashpoint for 75W90 synthetics #4
That is incorrect.
Flashpoint is the temperature that a vapor os produced that can burn.
Auto ignite in most cases is much and often many times higher.
Thnx K7 !
I have not towed this heavy before, and have known people that have done in differentials towing.... I was surprised to see the difference in specs, it seemed larger than I would have thought likely.
Cost is only a secondary concern. Stock is 4 quarts, if I upgrade the cover it may be closer to 6 quarts, but no matter.
I hear you... either one should do the trick. Rgds, D.
   / Flashpoint for 75W90 synthetics #6
ditto that...
soundguy
It is a Dana, that reminds me, I was just under there, meant to write down the Dana #..... I usually hear good things about Dana, just trying to take the best care I can of a decent HD axle. :thumbsup:
I hear you on the 1/2 tons..... I wanted to go this heavy as I'm not a fan of being xyz+ miles from home with a multi-ton trailer and a beat to death 1/2 ton.
Thnx again K7.
Rgds, D.
   / Flashpoint for 75W90 synthetics #9
So Soundguy choses to "Diddo" inaccurate information yet once again.
Flashpoint IS NOT the same as auto ignition point.
Take a look:
Flash point - Wikipedia, the free encyclopedia
:p
it's 'ditto' and I don't know wht youre bone is with me?
I was was ditto'ing the " if you have temps that high you have other problems" portion.
getting around on this lil netbook with 8" screen makes it a tad difficult to fully edit and tweak every single mail sent out.
I'm glad that you focused on that single minor issue, than focusing on the entire post.
oh well.. another to add to the squelch bucket....
soundguy
   / Flashpoint for 75W90 synthetics #10
soundguy
I have a few on there myself.:D
2018 John Deere 460E Articulated Dump Truck (A51039)
2018 John Deere...
2004 Ford F-250 4x4 Crew Cab Mechanic Service Truck (A49461)
2004 Ford F-250...
2019 FORD F-650 SUPER DUTY BOX TRUCK (A51406)
2019 FORD F-650...
3014 (A50657)
3014 (A50657)
2025 78in Dual Cylinder Hydraulic Grapple Rake Skid Steer Attachment (A50322)
2025 78in Dual...
F-500 POWER PUMP 500HP TRIPLEX POWERED BY 3412 CATERPILLAR ENGINE (A50854)
F-500 POWER PUMP...
