Towing - How
   / Towing - How #22
I have seen that "Long, Long Trailer" movie several times, have it on VHS. What I remember most of all about it is when the guy first starts towing the trailer he gives this really anxious look over his shoulder at the bulk of the thing behind him...:D
I have an '85 Crown Victoria in my barn, purchased it new, going to restore it someday...it has the 5.0 V8 and factory towing package, rated for 5000 pounds, but never pulled anywhere near that much. My current car is an '04 Lesabre, it has much more power than the Ford does but the unibody limits the tow rating to a half ton. Engine is plenty strong, just hampered by a weak driveline and flimsy body structure. I really miss the old full frame cars for the reason they were built better, todays unibodies are marvels of weathersealing, and lack of rattles, very rust resistant but not worth a darn for towing. Too bad Detroit didn't build the body quality of todays new cars on full framed models....
   / Towing - How #23
Its funny to see tow ratings, a VW TDI Passat has something like 3 x the tow rating in europe than it does in North America, same car. They have their ratings based on maximum grade for decent with braked and unbraked trailers.
I lived for a while in Europe while working on a project... I was amazed to see little cars by US standards towing large travel trailers... true, the trailers were light weight... but still a lot of surface area to get blown around.
It became such a problem that many 2 lane mountain passes have severe travel trailer restrictions...
   / Towing - How #24
Yes... and many of the small Diesels have a surprising amount of torque.
A friend bought a new BMW 325it wagon and went to BMW to get a factory hitch for a singe jet ski... he was told by BMW it would void his warranty as the vehicle has no tow rating...
Funny thing is he bought the car European Delivery and just about every 325it he saw in Germany had a factory BMW hitch... he bought one in Germany and installed it when the car was state side.
He never had any problems... and if he did, he was ready to say how can BMW not warrant OEM???
   / Towing - How #25
Yeah the tow ratings are a bit funny, my 2001 F350 has a tow rating of something ridiculously low like 7000 lb. The exact same truck, with the v10 or diesel with low gears, the tow rating jumps to like 15,000 lbs so something like that. The brakes are identical, axles and frame identical etc. From what I've found its because there is a steep hill start and acceleration test to pass to get the tow rating. I don't live in the hills, I don't care if I can't rip from 0-60 in 20 sec, so I ignore the tow rating.
   / Towing - How #26
The factory considers possible warranty claims while determining towing ratings. If they didn't, on older trucks, a 460 gas (Ford as example) would have the same rating as the diesel as all suspension, brakes, tires etc. are identical and the power is similar. It is 2000lbs less. However,the 460 will carry more than a diesel as the gvw is the same and the gas engine is lighter. Here in British Columbia, the factory rated tow capacity (gross combined) is the law. Just ask all the U.S. visitors who got charged while towing big fifths. They won't let you move it at more than 10% overloaded. Your problem, they don't care. You might not get stopped, but don't get into an accident where the police or our government insurance is involved.
   / Towing - How #27
I read a story in Trailer Life one time that described a pickup owner who had an accident, someone pulled out in front of him and he was towing a travel trailer that weighed far in excess of what the tow rating of his truck was, he couldn't stop in time, the attorney for the driver of the car that pulled in front of the truck had the truck and trailer weighed and then claimed the truck driver was driving recklessly because he was towing a trailer that was in excess of the factory tow rating. Not sure if it ever happened though.
I had a '90 Ford F150 with a 4.9 six and automatic, 3.08 gears, factory tow rating was 5000 lbs, 10,000 lbs GCWR. Put the truck on a scale one time with all gear in back, fuel tanks full, cap, toolbox loaded, etc. Scale said 5,020 lbs. Towed a Jayco 30 foot TT, scale read 6345 with gear and LP tanks full. I was actually almost 1400 pounds over the factory GCWR. If I had the 5.0 V8 or 3.55 axle instead, GCWR was 12,000 lbs. factory and it would have been legal. WHY? More power or a lower axle ratio means no difference in how well you can turn or stop. I was still always extra careful towing because I didn't know if the story in TL actually happened or not. Any comments?
   / Towing - How #28
The F150 with the inline six I think had the 8.8 axle? The v-8's tended to have a heavier axle did they not?
Locally you are ticketed based on registered weight of tow vehicle and trailer and if you exceed any axle weights.
I would say sometimes the factory considers warranty. Its not always the limiting factor. Just like the original rear axle rating on my truck is exactly the sum of the original rear tire rating. I know the axle itself is rated to 9000 lbs, the rims are something like 3600 lb each. Current tires limit me to about 3400 lbs each.
   / Towing - How #29
The F150's all used the 8.8 rear axle, regardless of six or V8 that year, they began putting that size axle under trucks starting in '83. THe bigger F250 and F350 models used the bigger 10.25 inch rear axle in starting in '83.
   / Towing - How #30
Oh yes, forgot to mention, tire size was same on both 6 and V8, and the 6 actually weighed less than the V8 trucks.
1990 Ford F800 7 Yd. S/A Dump Truck (A48081)
1990 Ford F800 7...
2016 SDLG L948F WHEEL LOADER (A51242)
2016 SDLG L948F...
2018 INTERNATIONAL 4300 26FT BOX TRUCK (A51219)
2018 INTERNATIONAL...
2005 Ford F650 Fire Truck (A49461)
2005 Ford F650...
2019 Generac MLTS-1 2.4kW Towable LED Light Tower (A49461)
2019 Generac...
TOYOTA 8FGCU30 FORKLIFT (A50854)
TOYOTA 8FGCU30...
