Some new additions to my snow equipment for the season
   / Some new additions to my snow equipment for the season #1
DaleJR88Fan
Northeast IN
John Deere 2305
I have been working on making some additions to my snow removal equipment for this snow season.
First I added a rubber strip to my front blade and some red plow markers (not because I am a rookie, but because I like the looks). The rubber strip was cut from a stall mat from TSC and the markers are for Polaris plows.
Next I added a leg to my rear blade so it doesn't fall over and I don't need to search for a block to prop it up when I am putting it on or taking it off the tractor. Just some 3/4" black pipe with a foot of a short piece of scrap angle iron that slides up and down in a piece of 1" black pipe that I enlarged, on my 9 x 20 lathe, the ID to fit the 3/4" black pipe.
I also did something similar on the single bottom plow my dad found for me last year for $25.
Finally, this summer I bought a box of weight bench weights for $2 and I wanted to utilize then on my tractor when moving snow. The mount I ended up using was 1/2" black pipe (24" long) and a floor flange welded to the back of the blade to hold the pipe. To make the diameter of the pipe closer to the ID of the weights, I heated (slightly with my propane torch) 3/4" plastic electrical conduit and then hammered two separate pieces onto the black pipe till they met. It was a slow and tedious process, but it was the only way I could get an OD to fit the ID of the weights. Then once I installed the weights, I topped it off with a cap.
   / Some new additions to my snow equipment for the season #2
Great ideas.... I think I will 'borrow' a few of them. :) As soon as I decide on which welder I am going to buy.
   / Some new additions to my snow equipment for the season #3
Some neat ideas there.
Thanks for sharing.
   / Some new additions to my snow equipment for the season #4
I like the parking stands. I really need to make one for my landscape rake.
   / Some new additions to my snow equipment for the season #5
Parking stands will make life a lot easier
Nice pics
Joel
   / Some new additions to my snow equipment for the season #6
I like the parking stands - nice job. Did you drill a hole in the bottom so water will not collect in the pipe, causing it to freeze up and burst? Don't ask how I know about this. :eek:
   / Some new additions to my snow equipment for the season #7
Be sure to paint those parking stands a contrasting high visibility color as a reminder to make sure they're raised.
That Deere/Frontier/Woods rear blade parking stand is solid 1" round-bar. The replacements I made are Deere yellow.
Good point, even though my implements are are stored inside. I will add that when I paint them this spring.
Wow, that took a lot to bend 1" solid bar. I will take the advice, even though I triple check everything before I pull away. It doesn't hurt to have the visual color difference also.
   / Some new additions to my snow equipment for the season #9
I was physically and mentally tired when I bent the stand, so any redundant checking I'd normally do went out the window.
Deere/Frontier/Woods wanted $40 for a replacement stand. I made three and had them powder coated yellow for about the same cost. That way I have two spares in case I frak up again.
   / Some new additions to my snow equipment for the season #10
[/IMG]
Keep us posted on how well the stall mat works (I was going to do the exact same thing!)
Nice job ...
2006 INTERNATIONAL 7400 6X4 DUMP TRUCK (A52706)
2006 INTERNATIONAL...
2005 Chevrolet Silverado Pickup Truck, VIN # 1GCHK232X5F955091 (A57453)
2005 Chevrolet...
2021 Troy-Bilt TB110 21in Push Mower (A55973)
2021 Troy-Bilt...
2020 Case 5550 Trident (A56435)
2020 Case 5550...
2023 New Holland CR10.90 Combine - 332 Engine Hours - 244 Separator Hours (A56435)
2023 New Holland...
2016 Ford F-350 (A56858)
2016 Ford F-350...
