Some new additions to my snow equipment for the season
   / Some new additions to my snow equipment for the season #1
DaleJR88Fan
Northeast IN
John Deere 2305
I have been working on making some additions to my snow removal equipment for this snow season.
First I added a rubber strip to my front blade and some red plow markers (not because I am a rookie, but because I like the looks). The rubber strip was cut from a stall mat from TSC and the markers are for Polaris plows.
Next I added a leg to my rear blade so it doesn't fall over and I don't need to search for a block to prop it up when I am putting it on or taking it off the tractor. Just some 3/4" black pipe with a foot of a short piece of scrap angle iron that slides up and down in a piece of 1" black pipe that I enlarged, on my 9 x 20 lathe, the ID to fit the 3/4" black pipe.
I also did something similar on the single bottom plow my dad found for me last year for $25.
Finally, this summer I bought a box of weight bench weights for $2 and I wanted to utilize then on my tractor when moving snow. The mount I ended up using was 1/2" black pipe (24" long) and a floor flange welded to the back of the blade to hold the pipe. To make the diameter of the pipe closer to the ID of the weights, I heated (slightly with my propane torch) 3/4" plastic electrical conduit and then hammered two separate pieces onto the black pipe till they met. It was a slow and tedious process, but it was the only way I could get an OD to fit the ID of the weights. Then once I installed the weights, I topped it off with a cap.
   / Some new additions to my snow equipment for the season #2
Great ideas.... I think I will 'borrow' a few of them. :) As soon as I decide on which welder I am going to buy.
   / Some new additions to my snow equipment for the season #3
Some neat ideas there.
Thanks for sharing.
   / Some new additions to my snow equipment for the season #4
I like the parking stands. I really need to make one for my landscape rake.
   / Some new additions to my snow equipment for the season #5
Parking stands will make life a lot easier
Nice pics
Joel
   / Some new additions to my snow equipment for the season #6
I like the parking stands - nice job. Did you drill a hole in the bottom so water will not collect in the pipe, causing it to freeze up and burst? Don't ask how I know about this. :eek:
   / Some new additions to my snow equipment for the season #7
Be sure to paint those parking stands a contrasting high visibility color as a reminder to make sure they're raised.
That Deere/Frontier/Woods rear blade parking stand is solid 1" round-bar. The replacements I made are Deere yellow.
Good point, even though my implements are are stored inside. I will add that when I paint them this spring.
Wow, that took a lot to bend 1" solid bar. I will take the advice, even though I triple check everything before I pull away. It doesn't hurt to have the visual color difference also.
   / Some new additions to my snow equipment for the season #9
I was physically and mentally tired when I bent the stand, so any redundant checking I'd normally do went out the window.
Deere/Frontier/Woods wanted $40 for a replacement stand. I made three and had them powder coated yellow for about the same cost. That way I have two spares in case I frak up again.
   / Some new additions to my snow equipment for the season #10
[/IMG]
Keep us posted on how well the stall mat works (I was going to do the exact same thing!)
Nice job ...
EZ-GO Utility Cart (A55851)
EZ-GO Utility Cart...
2017 CAT 315F LCR EXCAVATOR (A58214)
2017 CAT 315F LCR...
Armstrong 64-405A Torque Wrench (A59076)
Armstrong 64-405A...
Sunray Family Fisher 17.5 18' Pontoon Boat (A53316)
Sunray Family...
2025 YOU-380 Mini Skid Steer Loader (New/Unused) Includes Bucket and accepts multiple attachments (A59225)
2025 YOU-380 Mini...
20Ft. Bi-Parting Wrought Iron Gate (New/Unused) Galvanized + Powder Coated (A59225)
20Ft. Bi-Parting...
