Rod in Forfar
- Joined
- Apr 10, 2010
- Messages
- 582
- Location
- Forfar, Ontario, Canada
- Tractor
- 1960 Massey Ferguson 35 (Perkins), 1995 TAFE 35DI, 1980 Bolens G174, 2005 Kubota B7510, 2020 Kioti Mechron 2200ps UTV Troy-Bilt Horse 2 1988 Case IH 255 4WD with loader and cab
Last summer we built a garage. Then I bought a very nice 10 X 7' "Mahogany"(hemlock with luan raised panels) door.
Today the time had come to install it.
All went well until I wound up the spring. I wonder if I had it in backwards. It took six turns and then it had had enough and hopped up onto the spindles holding it, losing its tension and blocking access to one of the holes on the shaft into which I needed to insert bars continue trying to tighten it.
My son and I and I jacked the door up and escaped the garage, but we did not solve the mystery of the door spring.
The way I turned it the spring grew shorter, compressing. Is this right, or should I have mounted it backwards, to elongate the spring?
The burnt-fingers method has shown me through a lot of diy adventures, but it seems to have let me down here.
Thanks,
Rod
Thanks,
Rod
