Need Horse Trailer Opinion
/ Need Horse Trailer Opinion
QRTRHRS said:
Based on your photo, I don't see the slope being all that bad. I have seen much much worse. What kind of miles are you looking at hauling?
Not a lot. 1300km run from Grande Prairie to Calgary to Regina next week, but other than that just locally, maybe one Alberta trip (1200km round trip) per summer.
I would be a bit nervous about the top of your bed.
It's OK, I inadvertently tested it within a minute of hooking up while leaving a parking lot with a steep approach. Some part of my body was VERY puckered, but everything survived, puckered parts and all.
-Jer.
/ Need Horse Trailer Opinion #22
Seems to me that most gn horse trailers going down the road are high in front. Seems to me that they should design these trailers with more clearance.
I've had to raise ours because of bed clearance issues with our driveway.
I don't know if it was related, but I did have a rear tire blow out. We were only carrying one horse.
I really don't think the slight incline bothers the horse.
We added a ramp to ours and love it. Much easier on the horses, especially backing out.
We have a Sundowner 3 horse living quarters. Nice trailer.
Ken
/ Need Horse Trailer Opinion #23
...It's OK, I inadvertently tested it within a minute of hooking up while leaving a parking lot with a steep approach. Some part of my body was VERY puckered, but everything survived, puckered parts and all.
-Jer.
Keep in mind that the clearance varies as you drive over different terrain, especially rough terrain. Be careful when you're making any kind of approach where the nose of the truck drops relative to the rest of the rig (i.e. driving off the shoulder of a road). Turning in a situation like this seems to compound the problem. Don't ask me how I know.
/ Need Horse Trailer Opinion #24
I hear ya. I had to pull a guy off a rail road crossing many years ago. He was driving a Dodge Dually and had a large 5th wheel, maybe 33', behind it. When the front of the truck broke over it got hung up. He was sitting there smoking the wheels even in 4 wheel drive trying to get it off. A tug from my F-150 was all it took to get him rolling again but the camper and the bed of the truck were already damaged.
Chris
/ Need Horse Trailer Opinion #25
I'm sorry if I offend anyone by posting a horse trailer Q on TBN, but I trust a lot of the opinions and experience on here.
Just bought a used Sundowner 3 horse slant. My truck has a 6" lift, and of course the trailer sits a bit nose high when there's no horses in it. It's 5" higher at the front of the trailer floor than the back, the drop is spread over 18' of floor. From what I can calculate thats a 2.3% grade, or about 2 degree slope. I need to hear your thoughts on 2 things:
1. Is this OK for the horses?
2. Is this OK for the load sharing on the front vs. rear trailer axle and tires?
I'll post a pic when the sun comes up.
Thanks, appreciate your input.
-Jeremy.
Ahh, lets see now...
I believe approximately as follows;
1) The horses probably won't care.
2) You can do some arithmetic about like this;
18ft of floor plus usually 8 1/2 ft on the front = 26 1/2 ft overall.
The "Pin" is all the way at the front, but the 6 inches of excess height is relative to about the center point between the trailer axles - measure that to figure the real pitch.
Figure what that pitch translates to between your trailer axle centers.
At a guess the next size up tires on the front axle will bring you back very close to an equalized load, e.g. 235/85 16 on the rear axle, 245/85 16 on the front.
This is legal, mixing tire sizes on the same axle isn't.
This is simpler and more likely to work than hacking around with spacers, safer to DIY and could work out cheaper too.
Let us know how the arithmetic works out and don't make mistakes with RADIUS vs DIAMETER.
The tire section is all that varies, e.g. 85% of 235mm vs 85% of 245mm = 8.5mm
which is about 1/3 inch .
/ Need Horse Trailer Opinion #26
Just a thought, what about getting a cheap set of wheels and the factory tire size for the truck. Might buy a few inches. If you're not towing it every week, it's a minor hassle to swap them out. Kinda kills the look of the truck though.
Having no clue what the factory size was and the what the current size is, I could be all wet on this one. From the distance picture the tires look to be pretty tall and fill the wheel wells even with a lift.
I could do that, but you're right, it'd look ridiculous. The truck tires on there are 37" x 13.5 R20's Toyo Open Country MT's.
'Filling' the fenders is an issue when it comes to aesthetics. If there would've been a 3 or 4" lift option I would have done that and gone with 35's. That would've saved a lot on rubber costs too.
-Jer.
This is what I was hoping to hear in the first place!! The trailer does need rubber soon, so I'm going to take the opportunity to go to 16's and level it out a bit. The guy at the dealership is a retired Rodeo Cowboy and he didn't think it was the end-of-the-world either.
Learned today that the ramp that came with the trailer (not installed) doesn't fit!! Not too happy about that.... Trailer dealer offered me a Sundowner ramp for $1400!!! I declined. Maybe I can make it work with my welder, or at minimum, I have some scrap aluminum to play with.
-Jer.
/ Need Horse Trailer Opinion #29
Road camber tips/tilts horses in a weird diagonal way in slant load trailers anyway.
Plus up/down hill and acceleration/braking dominate any slight nose high attitude of the tralier floor.
BTW, a LITTLE bit more load on the rear axle isn't a bad thing for stability.
Just check that the front isn't so lightly loaded that the brakes lock up WAY too soon and that the rear tires aren't overheating - quick check, 15 minutes down the highway with the trailer empty, feel them and compare front/rear on the same side.
Don't compare front left/right if you are driving in sunlight, solar gain is TRUE on black tires and if you are heading east/west the south side tires WILL be warmer.
Oh yeah, be sure your tire pressures are right when cold before heading out for this check (-:
/ Need Horse Trailer Opinion #30
I only just saw the picture.
Yes, that DOES appear to be too close to the truck's bed rails.
One driveway entrance could put some nasty scratches on the top edges of that truck bed.
If you will be hauling to/from horse shows you will almost certainly be doing some "pasture parking", so getting the truck tilted one way while the trailer is angled and tilted the other way will happen - figure worst case, or 90% towards it.
I would pull the tube out another 3 inches, maybe more.
Other than that, it doesn't look to be that much nose high ("Up hill").
/ Need Horse Trailer Opinion #31
I "whacked" my Sundowner the first time out, bol! Only it was not the truck bed as I was pulling it with a flatbed. I had a a couple of wheel barrows behind my cab and the gooseneck settled on the drop tube. When I turned into a parking lot with a ramp style of entrance, I put a ding in the front corner of the trailer.
The trailer was second hand but like new. The dealer had supposedly gone over it but I suppose people take it for granted that the tube would be torqued correctly.
Ramps vs step ups; that's another topic we could argue away on.
/ Need Horse Trailer Opinion #32
I've trailered horses. Live loads are definitely different than a static load(ie tractor, cargo).
I really really like lifted Jeeps and Trucks! But...
- The CG is higher. Things get out of balance too fast in an emergency
- the brakes don't work as well. The OP's brakes were made to work with 31" tall tires. 37" tall tires are heaviear, and have a much larger spinning mass. The brakes do not work as effectively, without upgrades.
- Things just dont hook up right, ie trailers
For the horses
- The taller the step, the harder to load/unload
- Higher CG, the trailer does not handle as well
- Higher CG, especially with a livestock load that moves, is not as controllable in a panic situation.
- Bigger tires on the trailer, same as truck. More spinning mass, with more wieght + less effective brakes.
I would worry about the clearance and tires for an off-road truck. I would not worry on the street; I would be more concerned with the safety of the horses.
I personally would lower the truck, whether by less lift, or maybe dropping to 35's. It'd be a safer overall towin combination. And, without the angle on the trailer it would be much nicer on the horses legs. Not to mention you can keep a lower floor height for easier loading.
Personally, I would get some 35-12.50x17's. Shorter tire, more sidewall. More sidewall will give a better ride. And, it will give you bettersidewall felx for out on the trail. Those 20's are a recipe for rim rash. Especially when you drop tire pressure on the trail.
IMHO after years of trailering, Rubicon ect...
/ Need Horse Trailer Opinion #33
One other thing... That looks like an F-350? I would make sure/verify those tires and rims are "E" rated for hauling a trailer full of horses. If those tires and rims are not rated for the GVWR of that truck, you may have derated yourself effectively to an F150...
That's one problem with large aftermarket tires/rims. They are not usually up to the wieght ratings of stock tires/rims...
It's a F350.
E rated, 3990lbs per tire. 99mph max speed. On second set of rubber, first ones lasted about 90000km.
Hauled 11000lb bobcats, 13000lb minihoes, 10000lb of hay, no problems. Pretty sure the aluminum 3 horse trailer with a 42" pony and 15.5h walker will be OK. Belgian's won't fit, unfortunately (love big horses, want a team eventually).
Brakes are a bit soft at 130,000km, fronts getting done this week. Rears are OK. Were fine initially after the lift and tires.
Rails are definitely a bit of a worry for me, but so far it's been OK, even with the big dip in that parking lot.
I do wish that I had waited for a 3 or 4" lift, as it'd saved these trailer problems. Next time.....
The longer the trailer, the better the angle. A 4 horse, or a 30' flatdeck, would've been fine I think. My 25' flatdeck is just a bit most high when empty.
-Jer.
In all honesty, I'm too chicken to take it really offroad, it's too expensive. I want to get an AEV Rubicon for that.....then we'll have some fun!!! The 350 is a pavement baby mostly.... The 4x4 gets engaged a few times a month for mud and snow, but certainly nothing I've headed into on purpose. The 20" rims are pretty safe tucked into those 37's. It's not exactly on 20 series on 26" spinner rims!!!
I appreciate what you saying about CG and stopping, etc. I know it doesn't seem like I would be, but I'm very cautious, borderline ****, about trailering anything...especially critters. It's far from 'tippy', with or without a load.
-Jer.
