New hole in my workbench.
/ New hole in my workbench. #1
dodge man
Super Star Member
West central Illinois
JD 2025R
I changed the oil in my new Challenger for the first time Friday night. I should have known better. If I counted correctly, this will be my ninth new Chrysler product. I've learned after the first couple, that they hire ex football players to put on oil filters at the engine plant. You know the kind, 350 lbs and can bench press 400 lbs or more. The Challenger was no different. Its fairly easy to get to with the socket style oil filter wrench, but all these did was spin on it. I mean this sucker was on there tight. :smiley_aafz:
Well I was finally able to get my giant sized, purchased just for removing oil filters, channel locks on it from the side by feeding them through the wheel well. This got it loose, but I could only turn it about 1/64th of a turn at a time. This took about 20 minutes just to get is loose enough to spin it off by hand. The entire process took about 2 hours.
The hole in the work bench? At some point, my channel locks made a sudden downward motion and made contact with my work bench followed by a rather long speech, you know the kind @#$%&*. This hole is right next to the hole in my work bench when I changed the oil in our 2000 300M.
The oil filter, by the time I got it off, it looked like I hit with the 60" MMM on my BX.........twice.
/ New hole in my workbench. #2
I don't understand, how did the pliers make a hole??? :confused: (or was it just a dent?)
The back of the jaw of the channel locks is what I hit the work bench with. Its a plywood top. Its more of a slot then a hole. It would be safe to say I hit the workbench pretty hard.
/ New hole in my workbench. #4
OK...:confused2:
/ New hole in my workbench. #5
Sounds like you need a better workbench..... LOL
Aaaaaaannnnnnd to stop buying Chrysler products!!!!!
Just kidding.....
When I lived near our office, I had a co-worker look me up one night and he caught me beating a wooden creeper over a T post, but thats another story. Maybe I need anger management?
/ New hole in my workbench. #7
I once caught my Dad hitting a string trimmer with a hammer...:confused2:
/ New hole in my workbench. #8
I feel for you. I have fought many oil filters. For some reason everyone thinks you need to put them on with 450 FT TQ on boat motors. I guess they do not want any oil to drip in the lake or something.
Chris
/ New hole in my workbench. #9
AND THEN YOU WONDER WHY WE CHARGE SO MUCH FOR OUR SHOP RATES!!!:laughing:
/ New hole in my workbench. #10
when ti's really really really stuck on.
Take a BF screwdriver and drive it right thru the SOAB at a 90 degree angle.
now you have leverage
then turn screwdriver.
it works
but it's scary, because if it doesn't come off, now the car doesn't run. (well, it will, but not for long)
/ New hole in my workbench. #11
An oil filter isn't considered tight until you've rippped the canister off the base and used a BFH on a punch in the oil passage holes to get it off. :D
/ New hole in my workbench. #12
I I've learned after the first couple, that they hire ex football players to put on oil filters at the engine plant. You know the kind, 350 lbs and can bench press 400 lbs or more. The Challenger was no different.
This guy must be the same service tech who used to work for a generator company that serviced our diesel powered building fire pump at work a few years ago. He had tightened the filters so much that he warped the gaskets which promptly spewed out all the oil at the next scheduled run of the pump. It cost his company a pretty good buck to have the Cummins engine rebuilt.
/ New hole in my workbench. #13
I threw a chainsaw accross the drive once and stuck it chain first through the wall of my shop.
/ New hole in my workbench. #14
Or a cold chisel and a hammer. My uncle once had to weld a pipe to a base plate to get one off when the canister came free. I hope I never have to go that route.
Chris
/ New hole in my workbench. #15
And our wives and girlfriends wonder why we drink and cuss. I had mine change out all the faucets in our kitchen and 3 bath rooms. She had a cut on her forehead, bloody knuckles, and a sore back. All she could say is I need a drink.
Chris
/ New hole in my workbench. #16
Same story on my F150. I have never seen an oil filter so tight. I nearly crushed the filter with large channel locks trying to break it loose.
Yeah I did the big screwdriver through the filter once. I barely got it loose because it started to shred.
/ New hole in my workbench. #19
Also, when I ever tighten a gas cap, I'm the only one who can get it off again...:laughing:
/ New hole in my workbench. #20
Mini-boss asked what the knuckle shaped dent was in the wall near the light switch in the living room, I said "a bad day at work".
Nothing worse than trashing your own stuff though.
Joel
