S-tine cultivator build....
   / S-tine cultivator build.... #11
Quality job my friend!
peter
Started some assembly tonite... was almost done painting the rollers when I ran out of paint... figures just my luck, lol But got the bearings bolted on, note the orientation of the grease zerks... all pointing up;);)
   / S-tine cultivator build.... #13
looks good can i live in that shop. having built one similar to that i found that the roller bearing holderoner bars need some side ti side support. the flex in turns at the end of the arena popped the set screws on the pillowblocks. i ended up welding on a chunk of 2 inch angle iron the whole length of the arm .
   / S-tine cultivator build.... #14
Thanks for posting this, great job by the way.
I'm getting ready to build my own from the wings off my brothers field cultivator.
What did you use to cut the roller harrow disks'?
Thanks
donais... thanks for the heads up on the roller arms!!!!!
jeff77.... I had my local steel shop plasma torch them out for me, he has a circle cutter jig for his plasma. Works SLICK!!! I went with 1/8" plate at 9" circles.
Thanks for the compliments fellas!!!!:drink:
   / S-tine cultivator build.... #16
Thanks, looks like need either buy or make a circle cutting attachment for my plasma cutter.
   / S-tine cultivator build.... #17
That is one nice cultivator! Great Job!
All DONE!!!! Or I hope;) lol...
All I can say is.... I am tickled pink errr "GREEN" over this build!!!!!!!!!! Can't wait to use it now!!
Note the last 2 pics of how I can remove the wings with a simple allen wrench and pull the lock collars and shaft;) That was another "build on the fly" design I came up with.
Thanks again for TBN and some folks for helping me out with the rollers and past pics!!!:drink::drink:
It works!!!!!! lol
   / S-tine cultivator build.... #20
Great, I have one other question.
What size shaft did you use for the roller harrow axle?
Thanks
Jeff
(APPROX 15) 2" X 6" X 20'- 3/8" THICK METAL TUBING (A54757)
(APPROX 15) 2" X...
2017 Freightliner MT55 Step Van (A56858)
2017 Freightliner...
2020 PETERBILT 567 (A58214)
2020 PETERBILT 567...
John Deere 5075E (A53317)
John Deere 5075E...
1298 (A58374)
1298 (A58374)
2017 VOLVO VNL TANDEM AXLE DAY CAB (A58018)
2017 VOLVO VNL...
