Turn Minihoe into excavator
   / Turn Minihoe into excavator #21
That is a 12" bucket and i believe a 24" scraper so you are probably correct. Works nice for grading after digging a trench.
Ken
Amazing what 50 degree temps and 3 inches of rain can do.
Here are pictures of the Lackender scraper. Had no light out there so had to shoot blind. It would be easy to make the blade deeper or wider if desired. This has worked well for me.
Ken
Today I pretty much copied the Lakender scraper. I made it two feet wide and out of channel 6 inches wide. I tested it on snow, gravel and a pile of logs today and it worked very well. Would anyone like to see pictures? I got lazy and did not take any today.
I originally thought about making it 44 inches wide since my piece of channel was that long. I realized this would put a lot of stress on the minihoe and bucket, so I cut it down to 24 inches.
   / Turn Minihoe into excavator #23
Sure, we always like pictures! :D
(Whenever you get around to it, at your leisure, of course. ;) )
I took some today. I knew you would ask. I can see that I welded the plate on crooked. This is the way it fit the teeth on the bucket best, but it looks bad.
The fourth pictures is insided the bucket. It shows the strap which is welded to the excavator and holds it hold with one bolt.
Today I actually used this for it's intended purpose. I cleared a ditch about 75 feet long in an hour. Very easy to do and I did not have to drive down into the muck. It's real nice to have the reach. I also did not tear up the ground around it from getting stuck. The last time I did this I had to get out the boat winch to pull the PT out. I am tempted to build a wider one, but I might damage the tractor. They are easy and cheap enough to have several.
UNUSED 1RMC MASSAGE CHAIR (A57193)
UNUSED 1RMC...
2016 Dodge Charger Sedan (A55853)
2016 Dodge Charger...
VERTICAL LIFTING CLAMP (A57192)
VERTICAL LIFTING...
Honda EM3500S Portable Gasoline Generator (A55851)
Honda EM3500S...
2011 Ford Explorer Limited AWD SUV (A56859)
2011 Ford Explorer...
2020 Freightliner M2 106 Elgin Eagle Series 4MF Street Sweeper Truck (A55852)
2020 Freightliner...
