I want to build a 3ph converter
   / I want to build a 3ph converter #1
alltoys
Vimy, Alberta
Montana R28
I need to build a converter to run a 5hp 3 phase motor on my new old lathe.
Some that I have seen start at $3000 and go up from there. There must be a way to build one for far less moneys.
   / I want to build a 3ph converter #4
I would rather buy a inverter that way you can change the speed of the lath very easy... on the fly even...
FYI lots of inexpensive drives now in the 240 single phase to 3 phase...
Mark
   / I want to build a 3ph converter #5
I would go with a VFD most Variable Frequency Drives can run 3 phase motors on single phase and can control speed as well.
   / I want to build a 3ph converter #6
My 50kw pto Winco alternator has 3 ph as well as single phase 110 and 240 v capability. (Just in case a home/farm generator was in the budget plans...)
   / I want to build a 3ph converter #8
I believe what you are looking for is a rotary phase converter. Take a look at
Building a Three Phase Converter or just search google for rotary phase converter. You'll find lots of other hits.
   / I want to build a 3ph converter #9
Iplayfarmer - unfortunately, the motor that you picked is a 3450 RPM motor.
I am almost positive that an engine lathe will have a 1725 RPM motor. Also, if you go from a three phase to a single phase motor, the starter will have to be up sized due to the higher current rating.
The least expensive option is to consider a variable speed drive, (inverter). It will provide soft start as well as speed adjustments. Drive technology has advanced far enough to really lower the cost.
You should be able to pick up a 5hp drive that will take 230v single phase in and 230v three phase out for under $400.
   / I want to build a 3ph converter #10
I agree with Iplayfarmer...buy a new 5hp motor for $150 or so, and then sell the 3phase motor
12V 20GPM Gasoline Fuel Transfer Pump (New/Unused) (A59225)
12V 20GPM Gasoline...
2016 SERCO 8500 KNUCKLEBOOM LOADER (A58018)
2016 SERCO 8500...
2014 Ag Spray Schaben Sidedresser (A56435)
2014 Ag Spray...
John Deere 5055E (A53317)
John Deere 5055E...
2016 CATERPILLAR 415F2 BACKHOE (A52709)
2016 CATERPILLAR...
2023 Load Trailer (A55787)
2023 Load Trailer...
