Kubota 2320 / JD 2320
/ Kubota 2320 / JD 2320 #1
Wabiv
Northern Ontario
Hi all, Have been lurking for awhile. I have been to all the local dealers and have decided it is between these two. I will have a FEL and RMSB to start. Eventually I will want a roto tiller. Any help will be appreciated
Thanks in advance.
/ Kubota 2320 / JD 2320 #2
Welcome Wabiv,
I have the Kubota B2320 and am mostly happy with it. I will say up front that I did not purchase mine brand new. I bought in last August when it was not quite 1 1/2 years old with 120 hours as it was too good of a deal to pass up. I have the LA304 loader and 60" MMM.
If I had bought a new machine, the B2320 and the JD 2320 were both on my list and I had looked at both in person, but had not driven either. My only complaint with the B2320 is that I find the forward and reverse pedals awkward to transition between. I have an average, size 10 foot and find I can't keep my foot positioned to just rock back and forth. As I gain experience with the machine I am getting more used to it but, overall I think I would prefer the side by side pedals.
The one concern I had with the JD was the position of the FEL hydraulic lines. The quick disconnects are located under the left side floor board and I felt could be prone to snagging when used in the wooded terrain of my property.
Overall both are fine machines.
/ Kubota 2320 / JD 2320 #3
I looked at both too, and ended up with the Kubota, mostly because it was available, and I needed something right then. Though it isn't important with the implements you are going to get initially, I really wish mine had position control on the 3 pt like the JD. I grew up using small tractors with steering brakes too, and I wish they were easier to use on my Kubota. In mud, snow, and sometimes when backdragging with the loader, etc. they are really handy. I do like the three range transmision on mine, fewer things hanging off the bottom, and the overall build quality. I have a QA on my loader, so that is a wash. I think the steering geometry on the JD is a little better for finish mowing since the tires seem to "lean" into the turn more, and seem less likely to tear the turf with the outside of the outside front tire. You can't really go wrong with either. It used to be that the implements like snowblowers, front blades, etc. were better matched on the Kubota, and that influenced my decision too, but I see that JD is addressing that.
Try them both, think about what things are most important to you, and have fun shopping!
/ Kubota 2320 / JD 2320 #4
Welcome Wabiv,
TO have your foot on the petal is very tough! Try and leave your heal on the floor till you need to back up. Even at that I often just bring my foot around and push up on the bottom of the forward petal for quick reverses.
/ Kubota 2320 / JD 2320 #6
One other thing that I wouls mention about the pedal arrangement is to try sitting sideways as you would be using a box blade, or rear mounted snowblower in reverse on both the JD, and Kubota tractors. I found, and you might too that the rear location of the reverse pedal is so much more comfortable to use in that position, and saves a lot of neck, and back strain when doing that kind of job.
/ Kubota 2320 / JD 2320 #7
I have owned both Kubota & John Deere tractors. Once you get used to the toe to heel control you'll be very happy with it... With John Deers side by side pedal control you can easily step on the wrong pedal at the wrong time. I've always felt J.D. should use the toe to heel control and Kubota should use J.D. placement of the steering brakes. That would make both brands better machines I.M.O.
/ Kubota 2320 / JD 2320 #8
Hey neighbour!
Test drive the both of them.
Also, assess the dealer support. That's a hugely important part of the relationship.
Can't go wrong with either leading brand though.
Thanks for all the info fellas. The Kubota dealer is going to drop one off for me to try tomorow. I will keep you posted.
Hey jimmyj nice to hear from you.
/ Kubota 2320 / JD 2320 #10
I have a Kubota 2320 (14 months) and am happy with it. I initially looked at the JD 2320 but did not get the price on it that I received on the Kubota. My impression was that they were both quality products.
Cheers,
Dennis
/ Kubota 2320 / JD 2320 #11
Blair, what the heck, buy both so you can give us a review!!:D:D
/ Kubota 2320 / JD 2320 #12
I think the steering geometry on the JD is a little better for finish mowing since the tires seem to "lean" into the turn more, and seem less likely to tear the turf with the outside of theoutside front tire
I've heard a few others mention this. How bad is it? Would love to see a video of the two tractors on the same turf making the same turn and see the difference, if any.
/ Kubota 2320 / JD 2320 #13
When I was researching my tractor. (ended up getting a B2630) I looked the B2x20s and 2x20s. I liked the small size, lighter weight and better loader specs on the Kubotas.
I had similar thoughts about the pedal lay out difference. Thought I'd like the Deere style and hate the Kubota style. I was wrong. When plowing snow in reverse on my rear snow blade. The reverse pedal is in a great spot and trying to reach the brake is at times difficult. I can't imagine having to reach for reverse petal on the deere for long periods of time.
As for Kubota vs Deere. Never owned any thing Deere. But I can say my 'bota has surpassed my expections.
Good luck!
Hey Jim, sounds great but I decided on just one. I am now the owner of a Kubota B2320 HST with a FEL and RMSB. Late Friday I had 22 tons of gravel delivered and spent a better part of Saturday working/playing.:D Thanks again for the info fellas, it was greatly appreciated.
/ Kubota 2320 / JD 2320 #15
Congratulations! I am sure you are going to love it. The more experience I get on my B2320 the more I love it!
/ Kubota 2320 / JD 2320 #16
Good choice, and I'm sure you will get many hours of work, and enjoyment from it. I like my Kubota a lot, but I do try to be objective about it.
/ Kubota 2320 / JD 2320 #17
Nice! Good for you, and welcome to the tractor club!
I'm kinda thinkin that 22 ton aint gonna be enough! Keep safe and be careful. You are going to have a TON of fun.
You realize of course that you will be broke from now on, implements, drive in shed, projects.......:p
