And you say I don't maintain my equipment
   / And you say I don't maintain my equipment #11
EEK!
Three words:
Angle iron. Welder.
Hope that helps!
   / And you say I don't maintain my equipment #12
I don't know what to call that. Is it cutter sod?
Thanks for all the suggestions. I found a pair of caster wheels off an old Exmark mower I used to have, and installed them on the brush hog. They are a little wide so I pried the forks apart a little. The tires are pretty tired and probably won't last long but if it looks like this type will work I'll order a pair of solid ones.
As to the photo, I seem to grow grass as good on steel as I do on soil. I had some nice saplings started on my landscape trailer also. Just gos to show how wet it was here this Summer.
   / And you say I don't maintain my equipment #14
Here's the information from my solid tires on our PT425 attachments.
They are made by Care Free Tires - Punture proof and flat free. apparently right here in the good old U.S. of A. They have the following numbers on them...
Care Free
4.10/3.50-4NHS
As I mentioned, they have a larger diameter axle hole than the PT425 pneumatic tires, but the hand truck dealer had bushings to fit.
Hope this helps...
Care Free
4.10/3.50-4NHS
Hope this helps...
Moss,
Thanks for the info. I assume your talking about the Carefree hand truck tires. Looks like they come with a 5/8" axle diameter. That's what I need. Going to put these on my list of possibilities.
   / And you say I don't maintain my equipment #16
Moss,
Yes. The hand truck tires. I use them on my 48" brush hog. I like them so much I use them on my 60" finish mower and my snow plow, too.
(5) 14" X 26# X 171" I BEAM (A57192)
(5) 14" X 26# X...
(6) 2000 LB TRAILER JACKS (A57192)
(6) 2000 LB...
2017 KENWORTH T800 TRI AXLE SLEEPER TRUCK (A57880)
2017 KENWORTH T800...
(4) Roadguider ST235/80R16 Tires (A56469)
(4) Roadguider...
2015 Deere 524K (A53317)
2015 Deere 524K...
2015 Peterbilt 320 T/A EZ-Pack Front Loader Garbage Truck (A55852)
2015 Peterbilt 320...
