Proper Way to Tie Down Your Mini NOT!
   / Proper Way to Tie Down Your Mini NOT! #1
Diamondpilot
Super Star Member
Daleville, IN
Jinma 254/284 Ford 861 Powermaster at work
Saw this and had to snap a pic. Stopped a Burger King on the way home from the lake and thought you guys would like this. Looks like those are the 1" straps that come on a 4 pack at Home Depot for about $15. Love the way they are hooked in the wheels, that will stay in a panic stop or maneuver.
He did have one on all 4 corners.
Chris
   / Proper Way to Tie Down Your Mini NOT! #2
Chris
It IS a SMALL car..................:eek:
Forgot to mention he had the parking brake set. Its not going anywhere.
Chris
   / Proper Way to Tie Down Your Mini NOT! #4
Looks like a good way to ruin an expensive wheel.....unless the strap snaps, then you get to ruin the whole car:D
   / Proper Way to Tie Down Your Mini NOT! #5
While not how id do it, he likely is "safe". ITs a smart car, and they only weigh 820KG (1800 Lbs). Most of those straps are mimimum 500kg rated. Those ones appear to be 750KG rated. That said, i only use those types or tie downs for my fourwheeler. For anything serious, i use my Erickson straps (10K).
Id use a heaver strap and go to the factory tie down locations on the frame (why he tied to the rim i dont know).
   / Proper Way to Tie Down Your Mini NOT! #6
I new they left those slots in the rims for something.
   / Proper Way to Tie Down Your Mini NOT! #7
Looks better than the bobcat I seen this on the way in to work no straps or chains and doing 75+ down the interstate.
He actually would not have been too bad if he would have simply laced the strap through the wheel and back to the tie down on the trailer. If he would have done this though the front portion of the front wheels and the rear portion of the back wheels it would have been secured pretty well.
The problem with the way he did it is if the wheel shifts any bit the hook on the wheel can easily come loose.
Chris
   / Proper Way to Tie Down Your Mini NOT! #9
While I don't think a mini only weighs 1800lbs, there are physics involved here. A minor front end collision or a panic stop would surely snap those things or bend the hook resulting in the car coming into the rear truck.
I'm no physics major by any stretch, but that is just STUPID.
   / Proper Way to Tie Down Your Mini NOT! #10
Don't know if these are right or not, but from Wiki:
Answer
From 2002 to 2005 the coupe weighed 2315 pounds and the convertible weighed 2700.
From the 2006 Mini Cooper Owner's Manual, Data Section, Weights: Mini
Curb weight, with all optional special equipment Mini Cooper with manual transmission 2,524/1,145 lbs/kg automatic transmission with Steptronic 2,557/1,160 lbs/kg
Mini Cooper S with manual transmission 2,679/1,215 lbs/kg automatic transmission with Steptronic 2,723/1,235 lbs/kg From MSN Auto Specs 2004 mini cooper S with manual = 2678lbs
2005 Big Tex 10PI 16ft. T/A Pipe Top Utility Trailer (A49461)
2005 Big Tex 10PI...
UNUSED Artificial Grass Turf (A50860)
UNUSED Artificial...
8 DRILL COLLAR (A50854)
8 DRILL COLLAR...
2014 John Deere 635F Grain Platform (A50657)
2014 John Deere...
71068 (A49346)
71068 (A49346)
2025 Swict 84in Bucket Skid Steer Attachment (A50322)
2025 Swict 84in...
