Supersteer / front blower question...
   / Supersteer / front blower question... #1
JerryK
Elite Member
Vanderbilt, Michigan, USeh?
Mahindra (2011)5035 HST TLB & (2016)2555 HST Cab & (2017)1526 HST(2018)Cub Cadet Pro Z 154L (1991) Caterpillar E70B
Anyone know if the supersteer axle is compatible with the front quick connect blower setup? Most of the pictures online show SS tractors with a bolt on front blade, and not with the front quick connect setup that is shown with the blowers/quick connect front blades/brushes. The quick connect looks too wide, for when the axle/tire on the SS rotates to the front of the tractor. The frame on the bolt on blade looks a lot narrower. I took a cruise up to my dealer today, but forgot to ask him about it.
   / Supersteer / front blower question... #2
FWIW, I have the QA front blade (72") for my tractor. Greg
Thanks for the info. I am starting the long process of thinking about a new tractor. Probably a lot will chainge on them by the time I pull the trigger, but lots of info to absorb in the meantime.
   / Supersteer / front blower question... #4
Hi Jerry
I just bought a TC45DA with supersteer
you can get/add a blower with no issues i just did a hole lot of research on it and am currently awaiting the arrival of my new 72 CSH blower? :D (you need a different sub frame with supersteer)
Let me know if you need any help?
Thanks. I am just look seeing now. Not in a big hurry to pull money out of the bank that I might need to live on later. I am just trying to stay up on what is availible if I get the itch. I am only 60, and have no problem with my rear blower non-cab'd 2240, but someday want to get me something newer with a soft cab, and either a front blower or Erskine front blower. My tractor is just a little under 5700 hours, and still runs great.
   / Supersteer / front blower question... #6
Hi Guys. I can confirm as well that the front 72CSH snowblower works with the sub-frame quick attach on a cabbed TC45DA tractor with super steer. I ran this set up last year with no issues and the front mounted snowblower is awesome! Looks like snow is on the horizon for us here in MN, so i'm taking my front end loader off this weekend and getting the snowblower installed so I'm all set for the white stuff. Let us know if you have any questions.
   / Supersteer / front blower question... #7
No questions just want pictures of your setup:)
   / Supersteer / front blower question... #8
LOL! We like pictures around here??? OK, I'll take some pix this weekend as I'm getting things set up and post them up. Think BIG snow! :D
Questions.......... 45DA'ers
1- What engine RPM do you have to run for your 2000RPM mid PTO speed. [my JD2240 runs the rear PTO @ 540RPM @ an engine RPM of 2100]????
2- Most front blowers have a chain reduction setup to lower the Mid PTO RPM, so the front blower impeller is not running @ 2000RPM. Do you have any idea what the impeller RPM for the 72" is??
Ask for questions, and you will receive............... [[ Thanks !!! ]]
   / Supersteer / front blower question... #10
JerryK-I recall one of your posts where you've made 12"x12" shoes for your snowblower to aid in floation so the blower doesn't sink into the unfrozen gravel driveway.I'm running a pipe on my front snowblower,but it could be better.Any chance you could post pictures?Or even stop by your place to have a look?You might be on to something with your pad set-up:might be just what I need!Thank you in advance.
2015 Kia Sportage LX SUV (A50860)
2015 Kia Sportage...
1240 (A50490)
1240 (A50490)
2013 Nissan Rogue SUV (A50860)
2013 Nissan Rogue...
2012 Cottrell EZ-4807 22.5 Ton Car Hauler Trailer (A50323)
2012 Cottrell...
2011 New Holland B95B Cab MFWD Loader Backhoe (A51039)
2011 New Holland...
2011 Honda Odyssey Mini Van (A50860)
2011 Honda Odyssey...
