KL-122 FEL on LK 3054
   / KL-122 FEL on LK 3054 #1
bob2230
The KL-122 won't pick the front tires off the ground. Is this a relief valve issue?
Also, anyone know if the neutral port and PB port on the FEL control valve are one and the same ?
Thanks Bob
Joel
Attached is the valve with the line in question in red
Thanks, Bob
   / KL-122 FEL on LK 3054 #4
Thanks Bob
Bob, I've got the same machine & loader. I initially thought my FEL wouldn't lift the tires off the ground too, but on occasion the tires did lift up.
Seems you have to invert the bucket (open section on the ground) then raise it up. Down pressure with the bucket in the normal position doesn't seem to raise the front end. Although my neighbor has a 1999 Kubota L35 TLB and he CAN raise it quite easily in the "normal" position.
Thanks, I'll try that.
Any idea which port on the loader is the PB port. Nelson Long told me to connect the PB hose to the T port on his electric hydraulic valve kit and we think it's the one that goes to the neutral port on the tractor.
Thanks again
Bob
(8) 2" x 27' , 5 Ton Ratchet Tie Downs (New/Unused) (A59225)
(8) 2" x 27' , 5...
2018 John Deere 2025R Tractor - 647 Hours (A56435)
2018 John Deere...
(4) ALUMINUM RIMS FOR KAWASAKI MULE (A58374)
(4) ALUMINUM RIMS...
Massey Ferguson 1745 Hesston series (A53317)
Massey Ferguson...
Great Dane Van Trailer 1989 (A56435)
Great Dane Van...
1995 Stoughton Enclosed Dry Van Trailer, VIN # 1DW1A5323SS900663 (A57453)
1995 Stoughton...
