TN65 hydraulic issues
   / TN65 hydraulic issues
well, initially I was going to straighten the steps and reweld them but they finally got so flat I just cut them off. And it DOES give me better access to the under side of the tractor. I need to get under it and reconnect the axle lock linkage which has come loose for some reason. I'm sure brush snagged it. I have a new cable for the 3 PH quick lift I need to install as well. I am getting used to the jaunty 45 degree angle of the exhaust stack. LOL I actually had a muffler shop make me up a custom exhaust so it goes from the muffler and dumps down so the exhaust doesnt hang in brush. Bounces the sound off the ground though and is louder.
   / TN65 hydraulic issues #22
I have a similar squealing notice in my tn 65, as mentioned above blogs. My Problem is, it is not always there, but when it starts and you steer, the front wheels, is sometimes goes away, when you drive, it sometimes goes away, when I use fel, it sometimes goes away. When the squealing noise starts, The hydraulic line going to the dump clutch valve block on the left side near the differential coming from the pressure filter, vibrates heavily. Any ideas on this? Buy the way, it started after I changed out all filter fluids etc, with filters from the dealer.
2024 Chevrolet Tahoe SUV (A56859)
2024 Chevrolet...
2020 DRAGON ESP...
2014 Komatsu D51PXI-22 (A55272)
2014 Komatsu...
Year: 2016 Make: Ford Model: Explorer Vehicle Type: Multipurpose Vehicle (MPV) Mileage: Plate: Body (A56859)
Year: 2016 Make...
2007 Mercedes Benz S550 AWD Sedan (A56859)
2007 Mercedes Benz...
New 40ft High Cube 6 Door Container (A59000)
New 40ft High Cube...
