Tools Explained
/ Tools Explained #1
murphy1244
Super Star Member
Ohio
Kubota 1120 RTV Kioti DK-40, MF-135, Ventrac 4500Y
TOOLS EXPLAINED
DRILL PRESS : A tall upright machine useful for suddenly snatching flat metal bar stock out of your hands so that it smacks you in the chest and flings your beer across the room, denting the freshly-painted project which you had carefully set in the corner where nothing could get to it.
WIRE WHEEL : Cleans paint off bolts and then throws them somewhere under the workbench with the speed of light. Also removes fingerprints and hard-earned calluses from fingers in about the time it takes you to say, 'Oh sh*t'
DROP SAW : A portable cutting tool used to make studs too short.
PLIERS : Used to round off bolt heads. Sometimes used in the creation of blood-blisters.
BELT SANDER : An electric sanding tool commonly used to convert minor touch-up jobs into major refinishing jobs.
HACKSAW : One of a family of cutting tools built on the Ouija board principle... It transforms human energy into a crooked, unpredictable motion, and the more you attempt to influence its course, the more dismal your future becomes.
VISE-GRIPS : Generally used after pliers to completely round off bolt heads. If nothing else is available, they can also be used to transfer intense welding heat to the palm of your hand.
OXYACETYLENE TORCH : Used almost entirely for lighting on fire various flammable objects in your shop. Also handy for igniting the grease inside the wheel hub out of which you want to remove a bearing race..
TABLE SAW : A large stationary power tool commonly used to launch wood projectiles for testing wall integrity.
HYDRAULIC FLOOR JACK : Used for lowering an automobile to the ground after you have installed your new brake shoes, trapping the jack handle firmly under the bumper.
BAND SAW : A large stationary power saw primarily used by most shops to cut good aluminum sheet into smaller pieces that more easily fit into the trash can after you cut on the inside of the line instead of the outside edge.
TWO-TON ENGINE HOIST : A tool for testing the maximum tensile strength of everything you forgot to disconnect.
PHILLIPS SCREWDRIVER : Normally used to stab the vacuum seals under lids or for opening old-style paper-and-tin oil cans and splashing oil on your shirt; but can also be used, as the name implies, to strip out Phillips screw heads.
STRAIGHT SCREWDRIVER : A tool for opening paint cans. Sometimes used to convert common slotted screws into non-removable screws and butchering your palms.
PRY BAR : A tool used to crumple the metal surrounding that clip or bracket you needed to remove in order to replace a 50 cent part.
HOSE CUTTER : A tool used to make hoses too short.
HAMMER : Originally employed as a weapon of war, the hammer nowadays is used as a kind of divining rod to locate the most expensive parts adjacent the object we are trying to hit.
UTILITY KNIFE : Used to open and slice through the contents of cardboard cartons delivered to your front door; works particularly well on contents such as seats, vinyl records, liquids in plastic bottles, collector magazines, refund checks, and rubber or plastic parts. Especially useful for slicing work clothes, but only while in use.
ADJUSTABLE WRENCH: aka "Another hammer", aka "the Swedish Nut Lathe", aka "Crescent Wrench". Commonly used as a one size fits all wrench, usually results in rounding off nut heads before the use of pliers. Will randomly adjust size between bolts, resulting in busted buckles, curse words, and multiple threats to any inanimate objects within the immediate vicinity.
Son of a ***** TOOL : Any handy tool that you grab and throw across the garage while yelling 'Son of a b*tch' at the top of your lungs. It is also, most often, the next tool that you will need.
/ Tools Explained #2
ADJUSTABLE WRENCH: also usable as a pry bar :)
Great list, made my day.
/ Tools Explained #4
Funny....:thumbsup:
Edit: Sadly, it brought back some memories.:ashamed:
/ Tools Explained #5
"Interesting list to start ! The SOB TOOL : Any handy tool that you grab and throw across the garage while yelling 'Son of a w*tch' at the top of your lungs. It is also, most often, the next tool that you will need."
I have actually witnessed this personally .
Followed by the G=d d--m Mther Trucker POS !!! Even seen a guy or two "duck" while the tool was thrown ! Didn't seem to matter if the tool was SnapOn or Harbor Fright ! :laughing:
/ Tools Explained #6
I once got pretty upset working on a car. My SOB tool that day was a wooden creeper I was beating over a T post as the neighbor walked up. Kind of scared him. I never did like that creeper anyway. The tool I mean not the neighbor.
/ Tools Explained #7
Neighbor probably stopped and thought “Well, maybe I WON’T ask to borrow his tools now.” And that’s probably well worth the price of a creeper.
/ Tools Explained #8
Good stuff Murph!!!!
/ Tools Explained #9
Fixing a headlite on an old rusty mustang, got pissed, threw the screw driver, harpooned the expensive hard to find radiator.
I still do it but, like the old golfer, he's learned to throw the clubs in the direction he's going! My buddy threw his $400 driver 25 ft up a tree and had to wait for a younger guy to climb up and get it, that was great!
/ Tools Explained #10
I didn't see this, but heard the testimony of someone who did. Seems like the mechanic was working under a truck, when one of the other guys threw a dead snake under there with him. After losing a substantial amount of hair and scalp to the bottom of the truck, the guy came out with blood in his eye (and hair) and cleared the yard with flying tools.
/ Tools Explained
Now that's Funny!
/ Tools Explained #12
Now that's Funny!
One thing I learned at a young country boy, if you want to get your knob scobbed, try scaring someone with a snake...especially someone who is really afraid of them. I have another good snake story; I'll see if I can find it.
/ Tools Explained #13
I have a hole in my garage wall and a couple of cracked ribs to testify to the accuracy of that statement.
/ Tools Explained #14
Thanks Murph, as someone says later in the thread, as we get older we throw the tools in the direction we're going. I really needed a laugh!
2025 JMR 66in Single Cylinder Brush Grapple Skid Steer Attachment (A59228)
2025 JMR 66in...
John Deere 855DXUV Gator (A57148)
John Deere 855DXUV...
2018 Chevrolet Silverado 1500 4x4 Crew Cab Pickup Truck (A60352)
2018 Chevrolet...
Year: 2011 Make: Chevrolet Model: Express Vehicle Type: Van Mileage: 118,735 Plate: Body Type: 3 (A59230)
Year: 2011 Make...
2018 KENWORTH T680 TANDEM AXLE SLEEPER (A59904)
2018 KENWORTH T680...
POWER MATE 12 SHANK CHISEL PLOW 3PT (A60430)
POWER MATE 12...
