I have owened this tractor for 25 years. Durning cold weather I always use the start aid to pre heat before starting. It has always worked and started my tractor while out in the unheated shed. It coil quit glowing through the view hole when turning the Ign Switch counter clockwise and holding about 30 seconds. It worked (glowed) off and on for a while. My question is which part may be the cause: 1) The start aid coil, 2) The ignition switch, or something farther down the line to the cylinder heaters? How can I test this problem without replacing multiple parts? All you experts please give me some advise.
